Zum Hauptinhalt wechseln
ASUS X550LB-DS71 Motherboard Replacement
Was du brauchst
  1. ASUS X550LB-DS71 Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 3 ASUS X550LB-DS71 Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 3 ASUS X550LB-DS71 Motherboard Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Make sure to switch off your laptop before starting.
    • Place the laptop on a flat surface with the bottom side facing upwards.
    • Using the Phillips #1 Screwdriver, remove the four 4mm screws in the back panel.
    • Using both hands, slide the back panel away from the laptop horizontally.
  2. ASUS X550LB-DS71 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Using the Phillips #0 Screwdriver, remove the ten 2mm screws at the marked locations.
    • At this point, it is advised to disconnect the hard drive from the motherboard.
  3. ASUS X550LB-DS71 Motherboard Replacement: Schritt 3, Bild 1 von 3 ASUS X550LB-DS71 Motherboard Replacement: Schritt 3, Bild 2 von 3 ASUS X550LB-DS71 Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Using the plastic opening tool, open the back cover of the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  4. ASUS X550LB-DS71 Motherboard Replacement: Schritt 4, Bild 1 von 2 ASUS X550LB-DS71 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Locate the three ribbon connectors.
    • Using the plastic opening tool, flip up all three gray tabs and remove the ribbon connectors from the motherboard.
    • Once the tabs are released, the ribbons will be easy to remove. Do not pull on the ribbons.
  5. ASUS X550LB-DS71 Motherboard Replacement: Schritt 5, Bild 1 von 2 ASUS X550LB-DS71 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Locate the gold ribbon connecting the motherboard to the display.
    • Lift up the tape and disconnect the ribbon.
  6. ASUS X550LB-DS71 Motherboard Replacement: Schritt 6, Bild 1 von 2 ASUS X550LB-DS71 Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Using the Phillips #0 Screwdriver, remove the nine 2mm screws at the marked locations.
  7. ASUS X550LB-DS71 Motherboard Replacement: Schritt 7, Bild 1 von 2 ASUS X550LB-DS71 Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Disconnect the WLAN Card from the motherboard by pulling the connector upwards.
    • Disconnect the optical drive from the motherboard by sliding it to the right.
  8. ASUS X550LB-DS71 Motherboard Replacement: Schritt 8, Bild 1 von 3 ASUS X550LB-DS71 Motherboard Replacement: Schritt 8, Bild 2 von 3 ASUS X550LB-DS71 Motherboard Replacement: Schritt 8, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Flip the motherboard to show the underside.
    • Locate the two square connections attached to the motherboard.
    • Disconnect them using blunt tweezers.
  9. ASUS X550LB-DS71 Motherboard Replacement: Schritt 9, Bild 1 von 3 ASUS X550LB-DS71 Motherboard Replacement: Schritt 9, Bild 2 von 3 ASUS X550LB-DS71 Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Using the Phillips #0 Screwdriver, remove the seven 2mm screws at the marked locations.
    • Remove the heat sink from the motherboard.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team S16-G1, Eyestone Fall 2017 Mitglied von USF Tampa, Team S16-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S16G1
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 18
Letzte 30 Tage: 63
Insgesamt: 2,548
