Zum Hauptinhalt wechseln
ASUS X550LB-DS71 Optical Drive Replacement
Was du brauchst
  1. ASUS X550LB-DS71 Optical Drive Replacement, Optical Drive: Schritt 1, Bild 1 von 3 ASUS X550LB-DS71 Optical Drive Replacement, Optical Drive: Schritt 1, Bild 2 von 3 ASUS X550LB-DS71 Optical Drive Replacement, Optical Drive: Schritt 1, Bild 3 von 3
    • Make sure to switch off your laptop before starting.
    • Place the laptop on a flat surface with the bottom side facing upwards.
    • Using the Phillips #1 Screwdriver, remove the four 4mm screws in the back panel.
    • Using both hands, slide the back panel away from the laptop horizontally.
  2. ASUS X550LB-DS71 Optical Drive Replacement: Schritt 2, Bild 1 von 1
    • Using the Phillips #0 Screwdriver, remove the ten 2mm screws at the marked locations.
  3. ASUS X550LB-DS71 Optical Drive Replacement: Schritt 3, Bild 1 von 3 ASUS X550LB-DS71 Optical Drive Replacement: Schritt 3, Bild 2 von 3 ASUS X550LB-DS71 Optical Drive Replacement: Schritt 3, Bild 3 von 3
    • Using the plastic opening tool, open the back cover of the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the cover.
  4. ASUS X550LB-DS71 Optical Drive Replacement: Schritt 4, Bild 1 von 2 ASUS X550LB-DS71 Optical Drive Replacement: Schritt 4, Bild 2 von 2
    • Using the Phillips #0 Screwdriver, remove the 2mm screw at the marked location.
    • Remove the Optical Drive by sliding it to the right.
Abschluss
Nathan Dyer
550 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S16-G1, Eyestone Fall 2017 Mitglied von USF Tampa, Team S16-G1, Eyestone Fall 2017
USFT-EYESTONE-F17S16G1
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 2,065
