Einleitung
This guide will show you how to replace the hard drive for the ASUS X552LAV-BBI5N08 laptop.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Battery is not showed in pictures.
    • Battery is not showed in pictures.
    • Flip the laptop face down.
  2. Slide the right button to the left.
    • Slide the right button to the left.
    • Hold the left button to the right.
    • While you hold the left button in position, slide the battery out by pushing it away from you.
    • Start by flipping the laptop face down.
    • Locate the bottom panel. It is at the opposite end of the battery.
    • Remove the two 12mm screws at the bottom panel with a Tri-wing Y1 screwdriver.
    • Remove bottom panel by lifting it up.
    • Locate the hard drive.
    • It is located in the bottom left corner.
    • Remove the four 5.5mm screws located on the hard drive case using a Tri-wing Y1 screwdriver.
    • Slide the hard drive out to the left.
    • Lift the hard drive out.
    • Once the hard drive is removed, place the hard drive at a different area.
    • Place the hard drive on its side.
    • Remove the four 5mm screws from the sides of the case by using a Tri-wing Y1 screwdriver.
    • Lift the hard drive out of the case.
Abschluss
Jason Vo
Mitglied seit 15.02.2018
857 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S17-G1, Boczar Spring 2018 Mitglied von USF Tampa, Team S17-G1, Boczar Spring 2018
USFT-BOCZAR-S18S17G1
4 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 49
