Zum Hauptinhalt wechseln
ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement
Was du brauchst
  1. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement, Battery: Schritt 1, Bild 1 von 2 ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement, Battery: Schritt 1, Bild 2 von 2
    • Using a pair of tweezers, pull put the SIM card tray and set it to the side.
  2. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 2 mm screws using a Torx T2 screwdriver.
  3. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: Schritt 3, Bild 1 von 2 ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: Schritt 3, Bild 2 von 2
    • Insert a prying tool between the screen and the metal backing of the phone at the bottom to remove backing from phone.
    • There will be a thin film connecting the two pieces. You do not need to remove this. Just fold the two pieces apart with the inside facing up.
  4. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: Schritt 4, Bild 1 von 1
    • Remove the two 3 mm screws, using the Phillips #00 screwdriver, on the silver band at the top of the battery and remove the band.
  5. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: Schritt 5, Bild 1 von 1
    • Peel back the silver tape.
  6. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: Schritt 6, Bild 1 von 1
    • Disconnect the battery connections.
  7. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: Schritt 7, Bild 1 von 1
    • Pry and remove the battery.
    • The underside of the battery is adhesive so make sure to pry the battery off gently.
  8. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement, Speaker/Charger Port/Headphone Jack: Schritt 8, Bild 1 von 3 ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement, Speaker/Charger Port/Headphone Jack: Schritt 8, Bild 2 von 3 ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement, Speaker/Charger Port/Headphone Jack: Schritt 8, Bild 3 von 3
    • Remove all screws 3mm, using the Phillips #00 screwdriver, at the bottom of the device.
  9. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: Schritt 9, Bild 1 von 1
    • Remove the black piece.
  10. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: Schritt 10, Bild 1 von 2 ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: Schritt 10, Bild 2 von 2
    • Unplug the wires.
  11. ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: Schritt 11, Bild 1 von 3 ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: Schritt 11, Bild 2 von 3 ASUS ZENFONE 3 Zoom Speaker/Charger Port/Headphone Jack Replacement: Schritt 11, Bild 3 von 3
    • Using the pry tool, pry up the circular piece and remove the board.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Henry Barrett
546 Reputation
4 Anleitungen geschrieben
University of Alabama, Team S2-G7, Bedsole Fall 2018 Mitglied von University of Alabama, Team S2-G7, Bedsole Fall 2018
UA-BEDSOLE-F18S2G7
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 1,018
