Einleitung
Most components that need to be replaced are inside the base of the laptop. The laptop back panel will need to be removed in order to reach the inner components. This guide will give a step-by-step walk-through on how to remove the back panel of the ASUS ZenBook UX302LA-BHI5T08. For safety, make sure to unplug and turn off the laptop before starting this guide. When the back cover is removed, make sure to use extreme caution as the inner components of the laptop will be exposed!
Was du brauchst
Eine weitere Person hat diese Anleitung absolviert.
