Zum Hauptinhalt wechseln
ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement
Was du brauchst
  1. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Back Cover: Schritt 1, Bild 1 von 2 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Flip the laptop over so the model stickers face the ceiling.
  2. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: Schritt 2, Bild 1 von 2 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Remove eleven 7mm Phillips #00 screws that secure the back cover.
    • Two screws are under the rubber pad.
  3. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: Schritt 3, Bild 1 von 2 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Using a spudger, carefully remove the back cover.
  4. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Battery: Schritt 4, Bild 1 von 2 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Battery: Schritt 4, Bild 2 von 2
    • Remove the six 3mm Phillips #00 screws holding the battery in place.
  5. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: Schritt 5, Bild 1 von 2 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the battery wires from the motherboard by pulling on the black tab using a spudger or your hands.
  6. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Carefully lift the battery up and out of the laptop.
  7. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Hard Drive: Schritt 7, Bild 1 von 3 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Hard Drive: Schritt 7, Bild 2 von 3 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement, Hard Drive: Schritt 7, Bild 3 von 3
    • Remove four 3 mm Phillips screws (two on each side) holding the hard drive in the frame
  8. ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: Schritt 8, Bild 1 von 2 ASUS ZenBook UX302LA-BHI5T08 Hard Drive Replacement: Schritt 8, Bild 2 von 2
    • Grip the side of the hard drive and slide it out of the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Joshua Letizia
193 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S4-G4, Saloman Fall 2019 Mitglied von UMass Dartmouth, Team S4-G4, Saloman Fall 2019
UMASSD-SALOMAN-F19S4G4
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 551
