Einleitung
This guide will focus on replacing the Hard Drive (HDD) in the ASUS ZenBook UX302LA-BHI5T08 laptop. This piece is considered an essential part of any computer device as it contains everything from the operating system to the very files saved on the device. The HDD is an easy replacement for any inexperienced individuals.
Was du brauchst
Disconnect the battery wires from the motherboard by pulling on the black tab using a spudger or your hands.
Remove four 3 mm Phillips screws (two on each side) holding the hard drive in the frame
Eine weitere Person hat diese Anleitung absolviert.
