Einleitung
This is a guide outlining how to remove and replace the daughter board (also known secondary board). Make sure the battery is completely removed before working on the daughter board as to prevent shorts in the circuitry As a precautions ground yourself to prevent frying the internal components. Also make sure to keep track of screws and label them.
Was du brauchst
Use the plastic tool to pry between the silver bezel and the back case
Work the tool around the device to free the back case
Remove the ribbon cables by lifting up the white retaining flap on the ZIF connectors, then pulling the ribbon cable away.
Remove the battery connector by prying it up away from the device using 2 plastic pry tools
Remove all 9 of the 1.5mm #00 Philips screws
Gently lift the battery out of the device
Use an opening pick or similar tool to separate the adhesive on the bottom and top of the battery.
To remove the ribbon cables, lift up the white retaining flap on the ZIF Connectors with a plastic pry tool
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Using the tweezers gently pull off the tape over the ribbon cable
Cut the warranty tape connecting the daughter board to the metal plate under the battery
Using the #00 Phillips head screwdriver, remove the remaining 1.5mm screws in the daughter board
Gently lift the daughter board from the device
5 weitere Personen haben diese Anleitung absolviert.
4 Kommentare
Thanks for helping me fix my beloved Zenpad!
Karen, where did you get the replacement daughter board? I can’t find one anywhere! - Christine
Bought it here:
https://www.asusparts.eu/en/Asus-90NP01M...
This is Part Number: 32YU1CB0000,
“ASUSparts” internal part number: 90NP01M0-R10010
Please clarify Step 9 - where exactly is the warranty tape that needs to be cut?
I have this unit and it stopped charging and stopped holding charge- I do not want to buy another unit as I invested a LOT of time in setting this one up…
Thanks
vshulyaker@gmail.com
