Einleitung
Once you have removed the battery you will be able to remove the motherboard from your device. Make sure the battery is completely removed before working on the motherboard as to prevent shorts in the circuitry As a precautions ground yourself to prevent frying the internal components. Also make sure to keep track of screws and label them.
Was du brauchst
Use the plastic tool to pry between the silver bezel and the back case
Work the tool around the device to free the back case
Remove the ribbon cables by lifting up the white retaining flap on the ZIF connectors, then pulling the ribbon cable away.
Remove the battery connector by prying it up away from the device using 2 plastic pry tools
Remove all 9 of the 1.5mm #00 Philips screws
Gently lift the battery out of the device
Use an opening pick or similar tool to separate the adhesive on the bottom and top of the battery.
Use a plastic opening tool to lift the black retaining flap on the ZIF Connector
Using the plastic prying tool, lift the small retaining flap on the ZIF Connectors holding the ribbon cables to the motherboard
Using the tweezers remove the connector gently from the yellow slot
Gently peel up the tape until is is completely released from the motherboard
Cut the warranty tape connecting the motherboard to the metal plate under the battery
Using the #00 Phillips head screwdriver, remove the remaining 1.5mm screws in the motherboard
Eine weitere Person hat diese Anleitung absolviert.
2 Kommentare
Where can I buy a spare motherboard for this device.
Where are the motherboard sold and how do I purchase micro USB ports
