Einleitung
Replacing the circuit in the charging cradle
Was du brauchst
Using a metal spudger gently pry the plastic outer case apart
Use the PH0 sized Phillips screwdriver to remove the three screws (2mm) holding the board to the cradle.
Gently pry up with your hands to pull the board off.
Ein Kommentar
If you had listed what components were on the board or at least taken a picture of the other side of the board, I might have given you some points.
