Zum Hauptinhalt wechseln
ASUS ZenWatch Charging Cradle Circuit board Replacement
Was du brauchst
  1. ASUS ZenWatch Charging Cradle Circuit board Replacement, Charging Cradle Circuit board: Schritt 1, Bild 1 von 3 ASUS ZenWatch Charging Cradle Circuit board Replacement, Charging Cradle Circuit board: Schritt 1, Bild 2 von 3 ASUS ZenWatch Charging Cradle Circuit board Replacement, Charging Cradle Circuit board: Schritt 1, Bild 3 von 3
    • Using a metal spudger gently pry the plastic outer case apart
    • Pry open a little bit on each side before trying to open fully
  2. ASUS ZenWatch Charging Cradle Circuit board Replacement: Schritt 2, Bild 1 von 3 ASUS ZenWatch Charging Cradle Circuit board Replacement: Schritt 2, Bild 2 von 3 ASUS ZenWatch Charging Cradle Circuit board Replacement: Schritt 2, Bild 3 von 3
    • Use the PH0 sized Phillips screwdriver to remove the three screws (2mm) holding the board to the cradle.
    • Gently pry up with your hands to pull the board off.
    • Don't grab directly on the USB port as you may loosen or bust the connections.
Abschluss
USF Tampa, Team 1-3, Sullivan Spring 2016 Mitglied von USF Tampa, Team 1-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G3
4 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
If you had listed what components were on the board or at least taken a picture of the other side of the board, I might have given you some points.
Nate Fansler - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 19
Insgesamt: 2,851
