Einleitung
Step-by-step guide in removing and replacing a faulty motherboard.
Was du brauchst
On the strap there is a knob. Sliding this knob towards the opposite side of the strap releases the tension on the spring bar, allowing you to pull the strap out..
Use the T5 Torx driver to remove the four screws on the case.
The case will pry easily off with just gentle hand pressure
Using the tweezers, gently remove the fabric protecting the battery connection.
Use the heavy duty spudger to gently push the contact towards the top of the case.
With the metal tweezers gently remove the fabric covering the connection on bottom right
Using the heavy duty plastic spudger pry up on the connection ribbon.
The protective plate is now ready to be safely removed.
With the heavy duty spudger pry up on the metal plate, in a counter-clockwise pattern
Remove loosened plate and set aside.
With heavy duty spudger lift up on final connection ribbon located on left corner.
With all the connections disconnected the motherboard can be gently pried up and out of the watch case.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Where could i get the new replacement motherboard for that? Please inform.. thanks :)
