Einleitung
A step-by-step guide to removing and installing a vibration motor
Was du brauchst
On the strap there is a knob. Sliding this knob towards the opposite side of the strap releases the tension on the spring bar, allowing you to pull the strap out..
Use the T5 Torx driver to remove the four screws on the case.
The case will pry easily off with just gentle hand pressure
In diesem Schritt verwendetes Werkzeug:Heavy-Duty Spudger$4.99
The protective plate is now ready to be safely removed.
With the heavy duty spudger pry up on the metal plate, in a counter-clockwise pattern
Remove loosened plate and set aside.
With heavy duty spudger lift up on final connection ribbon located on left corner.
With all the connections disconnected the motherboard can be gently pried up and out of the watch case.
With a flat metal spudger pry back the little metal clamps that hold the motor secure.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
