Zum Hauptinhalt wechseln
AT&T CL4940 Number Pad Replacement and Cleaning
Was du brauchst
  1. AT&T CL4940 Number Pad Replacement and Cleaning, Number Pad: Schritt 1, Bild 1 von 2 AT&T CL4940 Number Pad Replacement and Cleaning, Number Pad: Schritt 1, Bild 2 von 2
    • Unplug your device before beginning disassembly.
    • Remove the phone line from the back cover of the device.
    • Remove the power cord from the side of the device.
    • Remove the phone cable from the side of the device.
  2. AT&T CL4940 Number Pad Replacement and Cleaning: Schritt 2, Bild 1 von 1
    • Remove the five 4mm X 10mm screws from the back cover of the device using a Phillips #1 screwdriver.
  3. AT&T CL4940 Number Pad Replacement and Cleaning: Schritt 3, Bild 1 von 3 AT&T CL4940 Number Pad Replacement and Cleaning: Schritt 3, Bild 2 von 3 AT&T CL4940 Number Pad Replacement and Cleaning: Schritt 3, Bild 3 von 3
    • Using a metal spudger, pry the white, plastic cover from the gray, plastic bottom. Start from below the keypad and work your way evenly around the device.
    • There are brackets every few inches along the edge of the device. These may be difficult to pull apart.
    • The internals of the device will be accessible once the white, plastic cover and grey, plastic bottom are separated.
  4. AT&T CL4940 Number Pad Replacement and Cleaning: Schritt 4, Bild 1 von 3 AT&T CL4940 Number Pad Replacement and Cleaning: Schritt 4, Bild 2 von 3 AT&T CL4940 Number Pad Replacement and Cleaning: Schritt 4, Bild 3 von 3
    • Remove the five 5mm X 5mm screws located on the yellow side of the motherboard using a Phillips #1 screwdriver.
    • Set the motherboard out of the way.
  5. AT&T CL4940 Number Pad Replacement and Cleaning: Schritt 5, Bild 1 von 3 AT&T CL4940 Number Pad Replacement and Cleaning: Schritt 5, Bild 2 von 3 AT&T CL4940 Number Pad Replacement and Cleaning: Schritt 5, Bild 3 von 3
    • Remove the two 5mm X 8mm large number pad screws using a Phillips #1 screwdriver.
    • Remove the 5mm X 6mm latch screw using the same screwdriver.
    • Remove the small, metal latch.
    • Remove the plastic plate previously secured by the screws and latch.
  6. AT&T CL4940 Number Pad Replacement and Cleaning: Schritt 6, Bild 1 von 3 AT&T CL4940 Number Pad Replacement and Cleaning: Schritt 6, Bild 2 von 3 AT&T CL4940 Number Pad Replacement and Cleaning: Schritt 6, Bild 3 von 3
    • Remove the remaining six 5mm X 8mm large number pad screws using a Phillips #1 screwdriver.
    • Remove the two 3mm X 6mm small number pad screws using the same screwdriver.
    • Grab the edge of the number pad board and peel it away from the screw posts.
    • Using a clean towel or cloth, move the number pad board away from the keys that lie below.
    • Set the number pad board out of the way for further disassembly.
  7. AT&T CL4940 Number Pad Replacement and Cleaning: Schritt 7, Bild 1 von 2 AT&T CL4940 Number Pad Replacement and Cleaning: Schritt 7, Bild 2 von 2
    • Peel away the white, rubber mat and set it aside for cleaning.
    • Remove the main key pad and any remaining keys. Remember where each key is located for reassembly.
    • Clean the rubber mat with a damp paper towel to remove any dust or foreign substances.
    • Replace any broken or cracked keys.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
IUPUI, Team 2-2, Harley Spring 2016 Mitglied von IUPUI, Team 2-2, Harley Spring 2016
IUPUI-HARLEY-S16S2G2
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 443
