Einleitung
This guide will show you how to replace the worn-out earpad cushions on your Audio Technica ATH-M40x headphones. Whether you want to extend the life of your headphones, restore sound quality, or opt for cushions that provide a better fit, this guide has you covered.
Make sure replacement cushions match the specifications of the ATH-M40x model before you begin.
Was du brauchst
Turn the headphone cable counter-clockwise to unlock.
Remove the headphone cable by pulling it out.
With one hand, hold your headphones in place while the other grips the earpad cushion.
Gently pry the old earpad cushion off.
In diesem Schritt verwendetes Werkzeug:Microfiber Cleaning Cloths$3.99
Use a microfiber cloth to wipe off any moisture or debris from the headphone drivers before installing your new earpad cushion.
Align the edge of new cushion to your headphone driver.
Slide the cushion over the headphone drivers until it is fully attached.
