Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
To get to many components in the phone, one must remove the back panel. This guide will serve as a first step in replacing most of the components.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove five 9.5 mm Phillips #1 screws from the back panel of the phone. Remove five 9.5 mm Phillips #1 screws from the back panel of the phone. Remove five 9.5 mm Phillips #1 screws from the back panel of the phone.
    • Remove five 9.5 mm Phillips #1 screws from the back panel of the phone.
  2. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  3. Slide metal spudger into the crack around the Front Panel of the phone Be careful not to break the clips holding the Back Panel to the Front Panel Be careful not to break the clips holding the Back Panel to the Front Panel
    • Slide metal spudger into the crack around the Front Panel of the phone
    • Be careful not to break the clips holding the Back Panel to the Front Panel
  4. When setting the back panel down, be careful to not rip any of the wires off of the internal components
    • When setting the back panel down, be careful to not rip any of the wires off of the internal components
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Charles Messmore
520 Reputation
5 Anleitungen geschrieben
IUPUI, Team 1-1, Harley Spring 2016 Mitglied von IUPUI, Team 1-1, Harley Spring 2016
IUPUI-HARLEY-S16S1G1
4 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 224
