Zum Hauptinhalt wechseln
Einleitung
If there is difficulty hearing from the Handset, there may be an issue with the Handset Cord. Using this guide, remove the chord and reattach it to determine if it was not plugged in securely. If this does not fix the problem, try replacing the old cord with a new one.
  1. Locate the plug in jack on the bottom right side of the phone. Locate the plug in jack on the bottom right side of the phone. Locate the plug in jack on the bottom right side of the phone.
    • Locate the plug in jack on the bottom right side of the phone.
  2. Pinch the clip on the plug and pull the cord away from the base in order to release the cord from the base Pinch the clip on the plug and pull the cord away from the base in order to release the cord from the base Pinch the clip on the plug and pull the cord away from the base in order to release the cord from the base
    • Pinch the clip on the plug and pull the cord away from the base in order to release the cord from the base
  3. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  4. Locate the plug in jack on the handset.
    • Locate the plug in jack on the handset.
  5. Pinch the clip on the plug and pull away from the Handset in order to release the cord from the bottom of the handset Pinch the clip on the plug and pull away from the Handset in order to release the cord from the bottom of the handset Pinch the clip on the plug and pull away from the Handset in order to release the cord from the bottom of the handset
    • Pinch the clip on the plug and pull away from the Handset in order to release the cord from the bottom of the handset
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Charles Messmore
520 Reputation
5 Anleitungen geschrieben
IUPUI, Team 1-1, Harley Spring 2016 Mitglied von IUPUI, Team 1-1, Harley Spring 2016
IUPUI-HARLEY-S16S1G1
4 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 154
