Zum Hauptinhalt wechseln
Einleitung
Bad connections between the phone itself and the handset could be an issue. Replacing the defective internal phone jack will solve this problem.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove five 9.5 mm Phillips #1 screws from the back panel of the phone. Remove five 9.5 mm Phillips #1 screws from the back panel of the phone. Remove five 9.5 mm Phillips #1 screws from the back panel of the phone.
    • Remove five 9.5 mm Phillips #1 screws from the back panel of the phone.
  2. Slide metal spudger into the crack around the Front Panel of the phone Be careful not to break the clips holding the Back Panel to the Front Panel Be careful not to break the clips holding the Back Panel to the Front Panel
    • Slide metal spudger into the crack around the Front Panel of the phone
    • Be careful not to break the clips holding the Back Panel to the Front Panel
  3. When setting the back panel down, be careful to not rip any of the wires off of the internal components
    • When setting the back panel down, be careful to not rip any of the wires off of the internal components
  4. Using the precision tweezers, bend the golden tips of the green and red wires upward. The wires are pulled out from two wholes out of six whole. Make sure you remember which whole you pulled the wire out from.
    • Using the precision tweezers, bend the golden tips of the green and red wires upward.
    • The wires are pulled out from two wholes out of six whole. Make sure you remember which whole you pulled the wire out from.
    • Bend the wires slowly and gently to avoid breaking them.
  5. After bending the golden wire tips, pull the wires out from the back side of the phone jack. After bending the golden wire tips, pull the wires out from the back side of the phone jack. After bending the golden wire tips, pull the wires out from the back side of the phone jack.
    • After bending the golden wire tips, pull the wires out from the back side of the phone jack.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Noor Assaf
303 Reputation
2 Anleitungen geschrieben
IUPUI, Team 1-1, Harley Spring 2016 Mitglied von IUPUI, Team 1-1, Harley Spring 2016
IUPUI-HARLEY-S16S1G1
4 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 256
