Zum Hauptinhalt wechseln
Einleitung
The speakerphone is used to talk hands-free on the phone. When this feature is not working, you may consider replacing it.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove five 9.5 mm Phillips #1 screws from the back panel of the phone. Remove five 9.5 mm Phillips #1 screws from the back panel of the phone. Remove five 9.5 mm Phillips #1 screws from the back panel of the phone.
    • Remove five 9.5 mm Phillips #1 screws from the back panel of the phone.
  2. Slide metal spudger into the crack around the Front Panel of the phone Be careful not to break the clips holding the Back Panel to the Front Panel Be careful not to break the clips holding the Back Panel to the Front Panel
    • Slide metal spudger into the crack around the Front Panel of the phone
    • Be careful not to break the clips holding the Back Panel to the Front Panel
  3. When setting the back panel down, be careful to not rip any of the wires off of the internal components
    • When setting the back panel down, be careful to not rip any of the wires off of the internal components
  4. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  5. Remove Front Panel as shown. Remove Front Panel as shown.
    • Remove Front Panel as shown.
  6. Locate Speakerphone  and remove solder with soldering iron. Locate Speakerphone  and remove solder with soldering iron. Locate Speakerphone  and remove solder with soldering iron.
    • Locate Speakerphone and remove solder with soldering iron.
  7. Use the soldering iron to reconnect the wires to the new speaker.
    • Use the soldering iron to reconnect the wires to the new speaker.
  8. Place new speaker back in place.
    • Place new speaker back in place.
    • Make sure that all of the components are back in place.
  9. Replace Back Panel as shown. Replace Back Panel as shown. Replace Back Panel as shown.
    • Replace Back Panel as shown.
  10. Secure the Back Panel with the same screws using the iFixit Protech Screwdriver kit J1 or PH1 bit. Secure the Back Panel with the same screws using the iFixit Protech Screwdriver kit J1 or PH1 bit. Secure the Back Panel with the same screws using the iFixit Protech Screwdriver kit J1 or PH1 bit.
    • Secure the Back Panel with the same screws using the iFixit Protech Screwdriver kit J1 or PH1 bit.
Ziellinie
Ein weiterer Nutzer hat diese Anleitung absolviert.
Charles Messmore
520 Reputation
5 Anleitungen geschrieben
IUPUI, Team 1-1, Harley Spring 2016 Mitglied von IUPUI, Team 1-1, Harley Spring 2016
IUPUI-HARLEY-S16S1G1
4 Mitglieder
7 Anleitungen geschrieben
Why do all these repairs require NO PARTS to replace defective parts?
And, of course< there is no links to a place to purchase the needed parts...
rpoland - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 271
