Einleitung
If you are unable to hear anything during hands free calling, the internal speaker may need to be replaced. This guide will teach you how to disassemble your AT&T CL4940 corded answering system, and how to replace the speaker used for hands free calling. This is a fairly simple process, and it can be accomplished with minimal technical expertise.
Was du brauchst
Remove the phone line and the power cord from the back of the device.
Remove the phone cable from the side of the device.
Remove the five 4mm X 10mm Phillips head screws from the back cover of the device.
Starting from the bottom of the device, (using a metal spudger) separate the top (white) plastic piece from the bottom (gray) plastic piece.
Work your way across the bottom of the device, then to each side, and finally to the top.
The top and bottom pieces should separate, and the internals of the device will now be accessible.
Using wire cutters, sever both the red and the black wires connected to the microphone.
To remove the microphone from the device, gently wiggle it while pulling it apart.
