Zum Hauptinhalt wechseln
ATT CL4940 Internal Microphone Replacement
Was du brauchst
  1. ATT CL4940 Internal Microphone Replacement, Internal Microphone: Schritt 1, Bild 1 von 2 ATT CL4940 Internal Microphone Replacement, Internal Microphone: Schritt 1, Bild 2 von 2
    • Unplug your device before beginning disassembly.
    • Remove the phone line and the power cord from the back of the device.
    • Remove the phone cable from the side of the device.
  2. ATT CL4940 Internal Microphone Replacement: Schritt 2, Bild 1 von 1
    • Remove the five 4mm X 10mm Phillips head screws from the back cover of the device.
  3. ATT CL4940 Internal Microphone Replacement: Schritt 3, Bild 1 von 3 ATT CL4940 Internal Microphone Replacement: Schritt 3, Bild 2 von 3 ATT CL4940 Internal Microphone Replacement: Schritt 3, Bild 3 von 3
    • Starting from the bottom of the device, (using a metal spudger) separate the top (white) plastic piece from the bottom (gray) plastic piece.
    • Work your way across the bottom of the device, then to each side, and finally to the top.
    • There are brackets every few inches along the edge of the device. These may be difficult to pull apart.
    • The top and bottom pieces should separate, and the internals of the device will now be accessible.
  4. ATT CL4940 Internal Microphone Replacement: Schritt 4, Bild 1 von 1
    • Using wire cutters, sever both the red and the black wires connected to the microphone.
    • To remove the microphone from the device, gently wiggle it while pulling it apart.
Abschluss
Charles Moore
201 Reputation
2 Anleitungen geschrieben
IUPUI, Team 2-2, Harley Spring 2016 Mitglied von IUPUI, Team 2-2, Harley Spring 2016
IUPUI-HARLEY-S16S2G2
4 Mitglieder
8 Anleitungen geschrieben
Ein Kommentar
I'd rather install a new microphone instead of just reinstalling the old one.
Is there a link to where a new microphone can be purchased?
rpoland - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 17
Insgesamt: 645
