Zum Hauptinhalt wechseln
ATT CL4940 Internal Speaker Replacement
Was du brauchst
  1. ATT CL4940 Internal Speaker Replacement, Internal Speaker: Schritt 1, Bild 1 von 2 ATT CL4940 Internal Speaker Replacement, Internal Speaker: Schritt 1, Bild 2 von 2
    • Unplug your device before beginning disassembly.
    • Remove phone line and power cord from the back cover of the device.
    • Remove phone cable from the side of the device.
  2. ATT CL4940 Internal Speaker Replacement: Schritt 2, Bild 1 von 1
    • Remove the five 4mm X 10mm Phillips head screws from the back cover of the device.
  3. ATT CL4940 Internal Speaker Replacement: Schritt 3, Bild 1 von 3 ATT CL4940 Internal Speaker Replacement: Schritt 3, Bild 2 von 3 ATT CL4940 Internal Speaker Replacement: Schritt 3, Bild 3 von 3
    • Starting from the bottom of the device, use a metal spudger, separate the top (white) plastic piece from the bottom (gray) plastic piece.
    • Work your way across the bottom of the device, then to each side, and finally to the top.
    • There are brackets every few inches along the edge of the device. These may be difficult to pull apart.
    • The top and bottom pieces should separate, and the internals of the device will now be accessible.
  4. ATT CL4940 Internal Speaker Replacement: Schritt 4, Bild 1 von 1
    • Using wire cutters, sever both the red and black wires connected to the speaker.
    • Carefully remove the speaker from the assembly.
    • Be sure to remove the rubber gasket from the broken speaker. You will need this for reassembly.
Abschluss
Charles Moore
201 Reputation
2 Anleitungen geschrieben
IUPUI, Team 2-2, Harley Spring 2016 Mitglied von IUPUI, Team 2-2, Harley Spring 2016
IUPUI-HARLEY-S16S2G2
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 399
