Einleitung
If your handset is encountering difficulties, replacing the motherboard may resolve it. Use the anti-static wrist strap as a precautionary measure to prevent damage to the motherboard.
Was du brauchst
Find the bump where the battery cover meets the phone. Put your thumb here, and push and slide the cover down.
Unplug the battery by squeezing your hands on the small white plug and lifting it up.
The battery is now detached and ready to be removed by lifting it out.
In diesem Schritt verwendetes Werkzeug:Anti-Static Wrist Strap$7.95
Remove the two 3.65 mm screws on the motherboard with a PH1 screwdriver.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
