Zum Hauptinhalt wechseln
ATT Trek HD 9020A Screen Replacement
Was du brauchst
  1. ATT Trek HD 9020A Screen Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • To separate the screen from the back panel, run the plastic opening tool along the outer edge of the device.
  2. ATT Trek HD 9020A Screen Replacement: Schritt 2, Bild 1 von 1
    • Pull the screen away from the back panel.
  3. ATT Trek HD 9020A Screen Replacement, Battery: Schritt 3, Bild 1 von 2 ATT Trek HD 9020A Screen Replacement, Battery: Schritt 3, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the six 2.5 mm screws located around the perimeter of the battery.
  4. ATT Trek HD 9020A Screen Replacement: Schritt 4, Bild 1 von 2 ATT Trek HD 9020A Screen Replacement: Schritt 4, Bild 2 von 2
    • Use the plastic opening tool to disconnect the black battery connector.
    • Gently lift the battery out of the device.
  5. ATT Trek HD 9020A Screen Replacement, Motherboard: Schritt 5, Bild 1 von 2 ATT Trek HD 9020A Screen Replacement, Motherboard: Schritt 5, Bild 2 von 2
    • Using a Phillips #00 screwdriver, remove the seven 1 mm screws on the green perimeter of the motherboard.
  6. ATT Trek HD 9020A Screen Replacement: Schritt 6, Bild 1 von 2 ATT Trek HD 9020A Screen Replacement: Schritt 6, Bild 2 von 2
    • Use the plastic opening tool to disconnect the large gold strip underneath the metal plate from the motherboard.
  7. ATT Trek HD 9020A Screen Replacement: Schritt 7, Bild 1 von 1
    • Use the plastic opening tool to disconnect the front and back cameras from motherboard.
  8. ATT Trek HD 9020A Screen Replacement: Schritt 8, Bild 1 von 2 ATT Trek HD 9020A Screen Replacement: Schritt 8, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    $3.99
    • Use angled tweezers to pry up the black tab.
    • Use the angled tweezers to pull out the gold connector.
  9. ATT Trek HD 9020A Screen Replacement: Schritt 9, Bild 1 von 2 ATT Trek HD 9020A Screen Replacement: Schritt 9, Bild 2 von 2
    • Use the angled tweezers to disconnect the gold connector.
  10. ATT Trek HD 9020A Screen Replacement: Schritt 10, Bild 1 von 1
    • Use the plastic opening tool to disconnect the black connectors on each side of the motherboard.
  11. ATT Trek HD 9020A Screen Replacement: Schritt 11, Bild 1 von 2 ATT Trek HD 9020A Screen Replacement: Schritt 11, Bild 2 von 2
    • Use the plastic opening tool to lift the motherboard out of place.
  12. ATT Trek HD 9020A Screen Replacement, Front Camera: Schritt 12, Bild 1 von 2 ATT Trek HD 9020A Screen Replacement, Front Camera: Schritt 12, Bild 2 von 2
    $3.99
  13. ATT Trek HD 9020A Screen Replacement, Screen: Schritt 13, Bild 1 von 3 ATT Trek HD 9020A Screen Replacement, Screen: Schritt 13, Bild 2 von 3 ATT Trek HD 9020A Screen Replacement, Screen: Schritt 13, Bild 3 von 3
    • Use the Phillips #00 screwdriver to remove the six 3 mm screws holding the black plastic corner pieces in place.
    • Gently lift the black corner pieces out of the device.
  14. ATT Trek HD 9020A Screen Replacement: Schritt 14, Bild 1 von 2 ATT Trek HD 9020A Screen Replacement: Schritt 14, Bild 2 von 2
    $3.99
    • Use the angled tweezers to remove the black cables on each side of the device from their groove.
  15. ATT Trek HD 9020A Screen Replacement: Schritt 15, Bild 1 von 2 ATT Trek HD 9020A Screen Replacement: Schritt 15, Bild 2 von 2
    • Use the plastic opening tool to disconnect the black cable connectors from each side of the device.
  16. ATT Trek HD 9020A Screen Replacement: Schritt 16, Bild 1 von 2 ATT Trek HD 9020A Screen Replacement: Schritt 16, Bild 2 von 2
    • Remove the remaining ten 3 mm Phillips #00 screws.
  17. ATT Trek HD 9020A Screen Replacement: Schritt 17, Bild 1 von 2 ATT Trek HD 9020A Screen Replacement: Schritt 17, Bild 2 von 2
    • Use the plastic opening tool to disconnect the remaining three gold connectors at the bottom of the device.
  18. ATT Trek HD 9020A Screen Replacement: Schritt 18, Bild 1 von 2 ATT Trek HD 9020A Screen Replacement: Schritt 18, Bild 2 von 2
    • Use the plastic opening tool to pry up the grey plastic panel.
  19. ATT Trek HD 9020A Screen Replacement: Schritt 19, Bild 1 von 2 ATT Trek HD 9020A Screen Replacement: Schritt 19, Bild 2 von 2
    • Use the plastic opening tool to pry the screen out of the device.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 32
Insgesamt: 871
