Was du brauchst
Use Jimmy to Separate screen from back cover. There is a thin gap. use picks to keep gap open while working around all edges.
Disconnect the Battery using the Spudger
Remove 6 #p000 screws to remove Battery
remove screw and carefully remove shield holding down ribbon
Use Spudger to carefully disconnect ribbon cables
Disconnect ribbon for Cameras
Fast fertig!
Abschluss
