Einleitung
You will need to open up the phone in order to be able to detach the back cover and replace it. This repair might be needed if there is no ring coming from the phone.
Was du brauchst
Open up the phone with a metal spudger, sticking it in the bottom near the cord jack entry.
Pull up on the spudger while simultaneously pulling up the top shell of the phone.
After unclipping the bottom half of the shell, pull upward from the position shown in the picture to detach the top half of the shell.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
