Zum Hauptinhalt wechseln
ATT Trimline 210M Key Pad Replacement
Was du brauchst
  1. ATT Trimline 210M Key Pad Replacement, ATT Trimline 210M Back Cover Disassembly: Schritt 1, Bild 1 von 1
    • Open up the phone with a metal spudger, sticking it in the bottom near the cord jack entry.
    • Be careful with the amount of force you use, or the plastic may crack.
  2. ATT Trimline 210M Key Pad Replacement: Schritt 2, Bild 1 von 1
    • Pull up on the spudger while simultaneously pulling up the top shell of the phone.
  3. ATT Trimline 210M Key Pad Replacement: Schritt 3, Bild 1 von 1
    • After unclipping the bottom half of the shell, pull upward from the position shown in the picture to detach the top half of the shell.
    • The cord connecting the speaker is short, and may detach if not done carefully.
  4. ATT Trimline 210M Key Pad Replacement: Schritt 4, Bild 1 von 1
    • You will have the motherboard and speaker exposed to you.
  5. ATT Trimline 210M Key Pad Replacement, ATT Trimline 210M Motherboard Disassembly: Schritt 5, Bild 1 von 1
    • Remove the two 10 mm screws using the 1/4" driver and a J1 Phillips screw head.
  6. ATT Trimline 210M Key Pad Replacement: Schritt 6, Bild 1 von 1
    • Carefully move the motherboard up to remove it.
  7. ATT Trimline 210M Key Pad Replacement, Key Pad: Schritt 7, Bild 1 von 1
    • Remove the speaker volume switch before trying to separate the keypad
  8. ATT Trimline 210M Key Pad Replacement: Schritt 8, Bild 1 von 1
    • Carefully push the black tabs back to dislodge the motherboard.
  9. ATT Trimline 210M Key Pad Replacement: Schritt 9, Bild 1 von 1
    • Remove keypad bundle.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Corey
343 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 4-2, Lacy Spring 2016 Mitglied von USF Tampa, Team 4-2, Lacy Spring 2016
USFT-LACY-S16S4G2
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 428
