Einleitung
You will learn how to replace the microphone on the phone. You may need to replace the microphone if people on the other side of the line are unable to hear you consistently.
Was du brauchst
Open up the phone with a metal spudger, sticking it in the bottom near the cord jack entry.
Pull up on the spudger while simultaneously pulling up the top shell of the phone.
After unclipping the bottom half of the shell, pull upward from the position shown in the picture to detach the top half of the shell.
Remove the two 10 mm screws using the 1/4" driver and a J1 Phillips screw head.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
