Einleitung
You will need to remove the back cover to access the motherboard. The motherboard is held down by two screws, be careful however, since there are many wires attached to the motherboard from speakers and the microphone.
Was du brauchst
Open up the phone with a metal spudger, sticking it in the bottom near the cord jack entry.
Pull up on the spudger while simultaneously pulling up the top shell of the phone.
After unclipping the bottom half of the shell, pull upward from the position shown in the picture to detach the top half of the shell.
Remove the two 10 mm screws using the 1/4" driver and a J1 Phillips screw head.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
