Einleitung
You may need to replace the speaker if you are unable to hear people from the other side of the line consistently. The speaker is glued on to the inside of the phone, so you may need to use a superglue or something similar to reattach the new speaker.
Was du brauchst
Open up the phone with a metal spudger, sticking it in the bottom near the cord jack entry.
Pull up on the spudger while simultaneously pulling up the top shell of the phone.
After unclipping the bottom half of the shell, pull upward from the position shown in the picture to detach the top half of the shell.
Remove the two 10 mm screws using the 1/4" driver and a J1 Phillips screw head.
Use the iFixit iOpener to warm the adhesive from the front of the phone, in order to remove the speaker from the face plate safely.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
