Zum Hauptinhalt wechseln
AUX-208P1 Electric Kettle Temperature Controller Replacement
Was du brauchst
  1. AUX-208P1 Electric Kettle Temperature Controller Replacement, Temperature Controller: Schritt 1, Bild 1 von 2 AUX-208P1 Electric Kettle Temperature Controller Replacement, Temperature Controller: Schritt 1, Bild 2 von 2
    • Clean all the dirt on the bottom of the electric kettle.
  2. AUX-208P1 Electric Kettle Temperature Controller Replacement: Schritt 2, Bild 1 von 2 AUX-208P1 Electric Kettle Temperature Controller Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the three 19 mm screws at the bottom of the electric kettle.
    • Remove the base of the electric kettle.
    • Remove the LED indicator buckled on the base.
  3. AUX-208P1 Electric Kettle Temperature Controller Replacement: Schritt 3, Bild 1 von 2 AUX-208P1 Electric Kettle Temperature Controller Replacement: Schritt 3, Bild 2 von 2
    • Use combination pliers to clamp the connection between the electric kettle line and the old temperature controller to create a gap, and pull it off.
    • Don't use too much force to avoid damage to the line!
  4. AUX-208P1 Electric Kettle Temperature Controller Replacement: Schritt 4, Bild 1 von 1
    • Use combination pliers to remove the nuts holding down the old temperature controller.
  5. AUX-208P1 Electric Kettle Temperature Controller Replacement: Schritt 5, Bild 1 von 2 AUX-208P1 Electric Kettle Temperature Controller Replacement: Schritt 5, Bild 2 von 2
    • Remove the broken temperature controller.
    • Clean the bottom of the kettle to remove any dust or debris buildup.
  6. AUX-208P1 Electric Kettle Temperature Controller Replacement: Schritt 6, Bild 1 von 1
    • Align the socket on the bottom of the new temperature controller with the protrusion on the bottom of the electric kettle to assemble.
  7. AUX-208P1 Electric Kettle Temperature Controller Replacement: Schritt 7, Bild 1 von 1
    • Use combination pliers to reinstall the nuts holding down the temperature controller.
  8. AUX-208P1 Electric Kettle Temperature Controller Replacement: Schritt 8, Bild 1 von 1
    • Fasten the electric kettle circuit to the contact reed of the new temperature controller.
    • Gently pull the interface to ensure a firm installation.
  9. AUX-208P1 Electric Kettle Temperature Controller Replacement: Schritt 9, Bild 1 von 2 AUX-208P1 Electric Kettle Temperature Controller Replacement: Schritt 9, Bild 2 von 2
    • Re-buckle the removed LED indicator back to the base.
    • Buckle the base back to the bottom of the electric kettle.
    • Use a Phillips #0 screwdriver to three 19 mm screws on the bottom of the kettle.
Abschluss
重新组装设备时,请依次相反的拆卸顺序。
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
SHAN HUANG
193 Reputation
2 Anleitungen geschrieben
York University, Team S1-G30, O'Regan Winter 2021 Mitglied von York University, Team S1-G30, O'Regan Winter 2021
YORK-O'REGAN-W21S1G30
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 45
Insgesamt: 917
