Zum Hauptinhalt wechseln
AYL SoundFit Battery Replacement
Was du brauchst
  1. AYL SoundFit Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the four hex screws on the top of the device using a 2.5 hex screwdriver.
  2. AYL SoundFit Battery Replacement: Schritt 2, Bild 1 von 1
    • Place a spudger between the black plastic cover and the green case.
    • Pry the black cover away from the main casing and remove the cover.
  3. AYL SoundFit Battery Replacement: Schritt 3, Bild 1 von 1
    • Place a spudger between the black housing, which contains the woofer, and the outer rubber casing.
    • Pry the housing away from the body to reveal the motherboard, speaker, and battery.
  4. AYL SoundFit Battery Replacement: Schritt 4, Bild 1 von 2 AYL SoundFit Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove the two Phillips #00 screws securing the battery casing.
    • Remove the battery case to reveal the battery.
  5. AYL SoundFit Battery Replacement: Schritt 5, Bild 1 von 1
    • Desolder the positive and negative battery contacts from the motherboard.
    • Remove the battery from the device.
Abschluss
Dustin Moore
108 Reputation
1 Anleitung geschrieben
IUPUI, Team 3-3, Harley Spring 2016 Mitglied von IUPUI, Team 3-3, Harley Spring 2016
IUPUI-HARLEY-S16S3G3
4 Mitglieder
5 Anleitungen geschrieben
4 Kommentare
Which battery is this, and what is the mAH?
jlongsa - Antwort
3.7V 1500mAh, 5.55Wh
Coba Farr -
The charger works but it does not say chargeing
Zaira Cortes - Antwort
18650 battery
rich4349 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 22
Insgesamt: 2,784
