Einleitung
Use this guide to replace the battery of your AYL SoundFit. If your device's battery won't hold a charge, replacing the battery may resolve the problem.
Was du brauchst
Remove the four hex screws on the top of the device using a 2.5 hex screwdriver.
Place a spudger between the black plastic cover and the green case.
Pry the black cover away from the main casing and remove the cover.
Place a spudger between the black housing, which contains the woofer, and the outer rubber casing.
Pry the housing away from the body to reveal the motherboard, speaker, and battery.
Remove the two Phillips #00 screws securing the battery casing.
Remove the battery case to reveal the battery.
Desolder the positive and negative battery contacts from the motherboard.
Remove the battery from the device.
