Einleitung
Use this guide to replace the speaker of the AYL SoundFit.
Was du brauchst
Unscrew the four hex screws on the top of the device using a 2.5mm hex screwdriver.
Place a spudger between the black plastic cover and the green case.
Remove the black cover away from the main casing and remove the cover.
Place the spudger tool between the black housing, which contains the woofer, and the outer rubber casing.
Remove the housing away from the body to reveal the motherboard, speaker, and battery.
Using a soldering iron, heat up and remove both the positive and negative battery contacts from the motherboard.
Using a soldering iron, heat up and remove the positive and negative wire contacts from the motherboard.
Remove four Phillips #1 screws to detach the speaker form the module.
Extract the speaker from the body of the AYL SoundFit.
