Einleitung
In this guide you will learn how to remove the SD card circuit board to access the logic board. To access the logic board, you will need to unsolder two leads. For soldering instructions, please refer to steps 1 through 6 of this soldering guide.
Was du brauchst
Remove the following screws:
Two silver 3.15mm Phillips #00 screws on the right side of the camera
Two silver 2.08mm Phillips #00 screws on the left side of the camera
Remove the two indicated screws on the bottom of the camera:
The screw circled in red is a longer silver 3.15mm Phillips #00 screw
The screw circled in blue is a shorter silver 2.25mm Phillips #00 screw
Silver donut-shaped button will fall off. Place separately. Remove the plug covers on the right side of camera, labeled “PC/AV” and “DC IN 4.5V”.
To remove the front cover, gently hold the inside structure of the camera and slowly pull the front cover off.
On the front of the camera, in battery case, remove screws indicated:
Two black 2.05mm Phillips #00 screws
Flip the camera over to the backside and remove screws indicated:
The screw circled in red is a longer black 3.00mm Phillips #00 screw
The screw circled in blue is a shorter black 2.00mm Phillips #00 screw
Cautiously and gently pull up the control board at the upper left corner, next to the viewfinder.
