Zum Hauptinhalt wechseln
Accessing Nokia 3100b Vibrating Unit
Was du brauchst
  1. Accessing Nokia 3100b Vibrating Unit, Battery: Schritt 1, Bild 1 von 1
    • Make sure your phone is turned off.
    Frag FixBot
  2. Accessing Nokia 3100b Vibrating Unit: Schritt 2, Bild 1 von 1
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
    Frag FixBot
  3. Accessing Nokia 3100b Vibrating Unit, SIM Card: Schritt 3, Bild 1 von 1
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
    Frag FixBot
  4. Accessing Nokia 3100b Vibrating Unit: Schritt 4, Bild 1 von 1
    • Retrieve your SIM card.
    Frag FixBot
  5. Accessing Nokia 3100b Vibrating Unit, Vibrating Unit: Schritt 5, Bild 1 von 1
    • Separate the front cover from the base of the phone.
    • Set the front cover, as indicated, aside.
    Frag FixBot
  6. Accessing Nokia 3100b Vibrating Unit: Schritt 6, Bild 1 von 1
    • Remove the screws indicated using a T6 Torx screwdriver.
    • Remove them in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple).
    Frag FixBot
  7. Accessing Nokia 3100b Vibrating Unit: Schritt 7, Bild 1 von 1
    • Separate the screen assembly from the base of the phone.
    • Set the screen assembly, as indicated, aside.
    Frag FixBot
  8. Accessing Nokia 3100b Vibrating Unit: Schritt 8, Bild 1 von 1
    • The vibrating unit can now be accessed. Note its location in the phone.
    Frag FixBot
  9. Accessing Nokia 3100b Vibrating Unit: Schritt 9, Bild 1 von 1
    • The vibrating unit is held in place by friction. Access the bottom of the unit and push upward to release it from the base.
    Frag FixBot
  10. Accessing Nokia 3100b Vibrating Unit: Schritt 10, Bild 1 von 1
    • The vibrating unit is now removed.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 29-64, Johann Spring 2010 Mitglied von Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 67
Insgesamt: 1,936
