Zum Hauptinhalt wechseln
Accessing Nokia 3100b Vibrating Unit
Was du brauchst
  1. Accessing Nokia 3100b Vibrating Unit, Battery: Schritt 1, Bild 1 von 1
    • Make sure your phone is turned off.
  2. Accessing Nokia 3100b Vibrating Unit: Schritt 2, Bild 1 von 1
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Accessing Nokia 3100b Vibrating Unit, SIM Card: Schritt 3, Bild 1 von 1
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
  4. Accessing Nokia 3100b Vibrating Unit: Schritt 4, Bild 1 von 1
    • Retrieve your SIM card.
  5. Accessing Nokia 3100b Vibrating Unit, Vibrating Unit: Schritt 5, Bild 1 von 1
    • Separate the front cover from the base of the phone.
    • Set the front cover, as indicated, aside.
  6. Accessing Nokia 3100b Vibrating Unit: Schritt 6, Bild 1 von 1
    • Remove the screws indicated using a T6 Torx screwdriver.
    • Remove them in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple).
  7. Accessing Nokia 3100b Vibrating Unit: Schritt 7, Bild 1 von 1
    • Separate the screen assembly from the base of the phone.
    • Set the screen assembly, as indicated, aside.
  8. Accessing Nokia 3100b Vibrating Unit: Schritt 8, Bild 1 von 1
    • The vibrating unit can now be accessed. Note its location in the phone.
  9. Accessing Nokia 3100b Vibrating Unit: Schritt 9, Bild 1 von 1
    • The vibrating unit is held in place by friction. Access the bottom of the unit and push upward to release it from the base.
  10. Accessing Nokia 3100b Vibrating Unit: Schritt 10, Bild 1 von 1
    • The vibrating unit is now removed.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 29-64, Johann Spring 2010 Mitglied von Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 1,721
