Einleitung
This guide will demonstrate the steps needed to disconnect and replace the LCD in the Acer AL1714. A malfunction in this part can cause possible issues with the ability to view images on your device.
Was du brauchst
Take the edge tool or a metal ruler and insert it into the bezel.
Apply pressure and push down.
Do the same to the right side.
Once the side of the bezel facing you is decoupled, take the back cover and pry it loose.
Remove the Power Button Circuit Board Flat Flex Cable from the Power Supply board under the metal cover.
Pull the cord back and out of the way.
Turn the monitor around.
Unscrew the 1 screw holding the Flat Power Cable cover in place.
Lift up and remove the Flat Power Cable cover.
Lift up on the back of metal cage, slightly.
Pull the cage toward self.
Lift up on the Flat Flex Cable holder tabs to release the cords.
Lift up on the Flat Flex Cables and bend them out of the working area.
Carefully detach the Power Supply and Video Display boards at the connector joint.
3 weitere Personen haben diese Anleitung absolviert.
