1. Turn the monitor facedown. Unscrew the 5 screws holding the back cover on.
    • Turn the monitor facedown.
    • Unscrew the 5 screws holding the back cover on.
    • (This may require flipping the monitor and shaking the screws loose once they're already unscrewed)
  2. Take the edge tool or a metal ruler and insert it into the bezel. Apply pressure and push down. Do the same to the right side.
    • Take the edge tool or a metal ruler and insert it into the bezel.
    • Apply pressure and push down.
    • Do the same to the right side.
    • Once side of bezel facing you is decoupled, take the back cover and pry it loose.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Erfolgreich repariert? Genial!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  4. Remove the Power Button Circuit board Flat Flex Cable from the Power Supply board under the metal cage. Pull the cord back and out of the way. (It may be stuck down with adhesive)
    • Remove the Power Button Circuit board Flat Flex Cable from the Power Supply board under the metal cage.
    • Pull the cord back and out of the way.
    • (It may be stuck down with adhesive)
  5. Remove the Flat Flex Cables from the Power Button Circuit Board.
    • Remove the Flat Flex Cables from the Power Button Circuit Board.
Abschluss
Christopher Kelly
586 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 1-3, Brown Fall 2014 Mitglied von USF Tampa, Team 1-3, Brown Fall 2014
USFT-BROWN-F14S1G3
3 Mitglieder
5 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 483
