Einleitung
This guide will demonstrate the steps needed to disconnect and replace the Power Button Circuit Board in the Acer AL1714. A malfunction in this part can cause possible issues with the ability to turn your device on.
Was du brauchst
Turn the monitor facedown.
Unscrew the 5 screws holding the back cover on.
Take the edge tool or a metal ruler and insert it into the bezel.
Apply pressure and push down.
Do the same to the right side.
Once the side of bezel facing you is decoupled, take the back cover and pry it loose.
Remove the Flat Flex Cable from the Power Supply Board under the metal cover.
Pull the cord back and out of the way.
Turn the monitor around.
Unscrew the 1 screw holding the Flex Power Cable cover.
Lift up and remove the Flex Power Cable cover.
Lift up on the back of the metal cage slightly.
Pull the cage toward self.
Lift up on the Flat Flex Cable holder tabs to release cords.
Lift up on the Flat Flex Cables and bend them out of the working area.
Unscrew the 5 screws holding the Power Supply Board and Video Display boards on.
Carefully detach the Power Supply and Video Display boards at their connector joint.
3 weitere Personen haben diese Anleitung absolviert.
