Was du brauchst
Turn the monitor facedown.
Unscrew the 5 screws holding the back cover on.
Take the edge tool or a metal ruler and insert it into bezel.
Apply pressure and push down.
Do the same to the right side.
Once the side of the bezel facing you is decoupled, take the back cover and pry it loose.
Remove the Flat Flex Cable from the Power Supply board under the metal cover.
Pull the cord back and out of the way.
Turn the monitor around.
Unscrew the 1 screw holding the Flat Power Cable cover in place.
Lift up and remove the Flat Power Cable cover.
Lift up on the back of the metal cage slightly.
Pull the cage toward self.
Lift up on the Flat Flex Cable holder tabs to release the cords.
Lift up on the Flat Flex Cables and bend them out of the working area.
Unscrew the 5 screws holding the joined Power Supply and Video Display boards on.
Carefully detach the Power Supply and Video Display boards at their connector joint.
Replace the Power Supply Board with a new part.
Eine weitere Person hat diese Anleitung absolviert.
