Zum Hauptinhalt wechseln
Acer AL1714 Video Display Board
Was du brauchst
  1. Acer AL1714 Video Display Board, Video Display Board: Schritt 1, Bild 1 von 2 Acer AL1714 Video Display Board, Video Display Board: Schritt 1, Bild 2 von 2
    • Turn the monitor face-down.
    • Unscrew the 5 screws holding back cover on.
    • (This may require flipping the monitor over and shaking the screws loose once they're already unscrewed)
  2. Acer AL1714 Video Display Board: Schritt 2, Bild 1 von 3 Acer AL1714 Video Display Board: Schritt 2, Bild 2 von 3 Acer AL1714 Video Display Board: Schritt 2, Bild 3 von 3
    • Take the edge tool or a metal ruler and insert it into the bezel.
    • Apply pressure and push down.
    • Do the same to the right side.
    • Once the side of the bezel facing you is decoupled, take the back cover and pry it loose.
  3. Acer AL1714 Video Display Board: Schritt 3, Bild 1 von 3 Acer AL1714 Video Display Board: Schritt 3, Bild 2 von 3 Acer AL1714 Video Display Board: Schritt 3, Bild 3 von 3
    • Remove the Flat Flex Cable from the Power Supply board located under the metal cage.
    • Pull the cord back and out of the way.
    • (It may be stuck down with adhesive)
  4. Acer AL1714 Video Display Board: Schritt 4, Bild 1 von 3 Acer AL1714 Video Display Board: Schritt 4, Bild 2 von 3 Acer AL1714 Video Display Board: Schritt 4, Bild 3 von 3
    • Unscrew the cord anchors for the VGA port.
    • (Use needle nose pliers if they're too tight for removal by hand)
  5. Acer AL1714 Video Display Board: Schritt 5, Bild 1 von 2 Acer AL1714 Video Display Board: Schritt 5, Bild 2 von 2
    • Turn the monitor around.
    • Unscrew the 1 screw holding the Flat power Cable cover on.
    • Lift up and remove the Flat Power Cable cover.
    • (Careful: this may be sharp)
  6. Acer AL1714 Video Display Board: Schritt 6, Bild 1 von 1
    • Unscrew the 5 screws holding the metal cage on.
  7. Acer AL1714 Video Display Board: Schritt 7, Bild 1 von 2 Acer AL1714 Video Display Board: Schritt 7, Bild 2 von 2
    • Lift the back of the metal cage slightly.
    • Pull the cage toward self.
    • (Must be careful to free the cover of the VGA port and the power supply input)
  8. Acer AL1714 Video Display Board: Schritt 8, Bild 1 von 3 Acer AL1714 Video Display Board: Schritt 8, Bild 2 von 3 Acer AL1714 Video Display Board: Schritt 8, Bild 3 von 3
    • Lift the Flat Flex Cable holder tabs to release the cables.
    • Lift up on the Flat Flex Cables and bend them out of the working area.
  9. Acer AL1714 Video Display Board: Schritt 9, Bild 1 von 3 Acer AL1714 Video Display Board: Schritt 9, Bild 2 von 3 Acer AL1714 Video Display Board: Schritt 9, Bild 3 von 3
    • Unplug the 4 backlight wires from their ports on the Power Supply Board.
    • (Considering their size, the best way to unplug the backlight wires is by slowly jiggling the wires out of place)
  10. Acer AL1714 Video Display Board: Schritt 10, Bild 1 von 1
    • Unscrew the 5 screws holding the Power Supply and Video Display boards.
  11. Acer AL1714 Video Display Board: Schritt 11, Bild 1 von 2 Acer AL1714 Video Display Board: Schritt 11, Bild 2 von 2
    • Lift and remove the joined boards.
  12. Acer AL1714 Video Display Board: Schritt 12, Bild 1 von 3 Acer AL1714 Video Display Board: Schritt 12, Bild 2 von 3 Acer AL1714 Video Display Board: Schritt 12, Bild 3 von 3
    • Carefully detach the two boards at their connector joint.
    • Replace outlined part.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 1-3, Brown Fall 2014 Mitglied von USF Tampa, Team 1-3, Brown Fall 2014
USFT-BROWN-F14S1G3
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 19
Insgesamt: 712
