Zum Hauptinhalt wechseln
Einleitung
The EMI shield protects the power supply and circuit board from electromagnetic radiation.
  1. Lay the monitor on a flat surface so that the back is facing up.
    • Lay the monitor on a flat surface so that the back is facing up.
  2. Grab the hinge cover with both hands on either side of the stand. Squeeze inwards with your thumbs and fingers and lift up to remove the hinge cover.
    • Grab the hinge cover with both hands on either side of the stand.
    • Squeeze inwards with your thumbs and fingers and lift up to remove the hinge cover.
  3. Remove the four 12.1 mm Phillips #2 screws that hold the stand to the monitor. Support the monitor while removing the screws to prevent the monitor from falling.
    • Remove the four 12.1 mm Phillips #2 screws that hold the stand to the monitor.
    • Support the monitor while removing the screws to prevent the monitor from falling.
    • Lift up to detach the stand.
  4. Remove the five 9.5 mm Phillips #2 screws located around the perimeter of the monitor. Remove the five 9.5 mm Phillips #2 screws located around the perimeter of the monitor.
    • Remove the five 9.5 mm Phillips #2 screws located around the perimeter of the monitor.
  5. Starting at the corner of the monitor, wedge the small plastic opening tool between the back cover and the display bezel. Tilt the plastic opening tool up to separate the back cover from the display bezel. Continue around the perimeter of the monitor until the display bezel comes off.
    • Starting at the corner of the monitor, wedge the small plastic opening tool between the back cover and the display bezel.
    • Tilt the plastic opening tool up to separate the back cover from the display bezel.
    • Continue around the perimeter of the monitor until the display bezel comes off.
    • A reasonable amount of force is necessary to detach the back cover from the display bezel.
  6. Reposition the monitor so that the back is facing up. Grab the corners of the monitor and jiggle them upwards to detach the back cover from the inside of the monitor.
    • Reposition the monitor so that the back is facing up.
    • Grab the corners of the monitor and jiggle them upwards to detach the back cover from the inside of the monitor.
    • Lift the back cover up.
  7. Remove the two 5.7 mm Phillips #2 screws located on either side of the EMI shield. Remove the two 5.7 mm Phillips #2 screws located on either side of the EMI shield.
    • Remove the two 5.7 mm Phillips #2 screws located on either side of the EMI shield.
  8. Using a nut driver (or if necessary, needle-nose pliers), remove the two nuts on either side of the VGA input. Using a nut driver (or if necessary, needle-nose pliers), remove the two nuts on either side of the VGA input.
    • Using a nut driver (or if necessary, needle-nose pliers), remove the two nuts on either side of the VGA input.
  9. Grab the metal casing by the sides and slide it down towards the bottom of the monitor. Lift up to remove the metal casing. Beware, metal casing is sharp!
    • Grab the metal casing by the sides and slide it down towards the bottom of the monitor.
    • Lift up to remove the metal casing.
    • Beware, metal casing is sharp!
Abschluss
Cal Poly, Team 20-26, Maness Fall 2011 Mitglied von Cal Poly, Team 20-26, Maness Fall 2011
CPSU-MANESS-F11S20G26
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 9
Insgesamt: 1,126
