Zum Hauptinhalt wechseln
Acer Aspire E5-574-53QS Back Panel Removal
Was du brauchst
  1. Acer Aspire  E5-574-53QS Back Panel Removal, Acer Aspire  E5-574-53QS Back Panel Removal: Schritt 1, Bild 1 von 1
    • Turn the laptop so that the back panel faces up.
    • Remove eighteen screws from the back cover using a Phillips #0 screwdriver.
  2. Acer Aspire  E5-574-53QS Back Panel Removal: Schritt 2, Bild 1 von 3 Acer Aspire  E5-574-53QS Back Panel Removal: Schritt 2, Bild 2 von 3 Acer Aspire  E5-574-53QS Back Panel Removal: Schritt 2, Bild 3 von 3
    • Use a plastic opening tool to ease out the optical drive from the side of the laptop, then pull it the rest of the way out.
    • Remove the three screws along the edge of the optical drive port with a Phillips #0 screwdriver.
  3. Acer Aspire  E5-574-53QS Back Panel Removal: Schritt 3, Bild 1 von 2 Acer Aspire  E5-574-53QS Back Panel Removal: Schritt 3, Bild 2 von 2
    • Stick an opening tool into the seam of the laptop case and begin prying the back panel from the device to loosen it. Slowly move all the way around the laptop, prying periodically to release each of the clips.
    • Do not completely remove it. Only loosen the connection between the back panel and the laptop. Be careful not to damage the VGA port, as that can easily get caught on the back panel during this step.
    • Lift the back panel up to reveal the cable connecting the back case to the motherboard.
  4. Acer Aspire  E5-574-53QS Back Panel Removal: Schritt 4, Bild 1 von 3 Acer Aspire  E5-574-53QS Back Panel Removal: Schritt 4, Bild 2 von 3 Acer Aspire  E5-574-53QS Back Panel Removal: Schritt 4, Bild 3 von 3
    • Carefully remove the cable from the socket.
    • The socket is very sensitive, so be gentle when pushing the cable connector out.
    • Fully remove the back case from the device.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Rolf Konrad
159 Reputation
1 Anleitung geschrieben
Ein Kommentar
I need to know what kind of screews go on that laptop because i bought one like this without screews. Model in question is E5 722G-302Y but i think they are similar enough .
Vladimir Hromis - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 39
Letzte 30 Tage: 111
Insgesamt: 3,429
