Zum Hauptinhalt wechseln
Acer Aspire 3 A315-21-92FX Battery Replacement
Was du brauchst
  1. Acer Aspire 3 A315-21-92FX Battery Replacement, RAM: Schritt 1, Bild 1 von 1
    • Flip the Acer Aspire 3 A315-21-92FX over so the back-side is oriented to the upward position.
  2. Acer Aspire 3 A315-21-92FX Battery Replacement: Schritt 2, Bild 1 von 2 Acer Aspire 3 A315-21-92FX Battery Replacement: Schritt 2, Bild 2 von 2
    • Remove the single 2.5mm Phillips #0 screw.
  3. Acer Aspire 3 A315-21-92FX Battery Replacement: Schritt 3, Bild 1 von 1
    • Use the iFixit opening tool to remove the small cover.
  4. Acer Aspire 3 A315-21-92FX Battery Replacement: Schritt 4, Bild 1 von 3 Acer Aspire 3 A315-21-92FX Battery Replacement: Schritt 4, Bild 2 von 3 Acer Aspire 3 A315-21-92FX Battery Replacement: Schritt 4, Bild 3 von 3
    • Press the tabs on each side of the RAM outwards, and the memory module will pop up at an angle.
  5. Acer Aspire 3 A315-21-92FX Battery Replacement: Schritt 5, Bild 1 von 2 Acer Aspire 3 A315-21-92FX Battery Replacement: Schritt 5, Bild 2 von 2
    • Pull the RAM slowly out of the Acer Aspire 3 A315-21-92FX.
  6. Acer Aspire 3 A315-21-92FX Battery Replacement, Hard Drive: Schritt 6, Bild 1 von 1
    • Please make sure that there is no external access to the battery, and the battery is out of power.
    • Flip the Acer Aspire 3 A315-21-92FX over, so the back-side is oriented to the upward position.
  7. Acer Aspire 3 A315-21-92FX Battery Replacement: Schritt 7, Bild 1 von 2 Acer Aspire 3 A315-21-92FX Battery Replacement: Schritt 7, Bild 2 von 2
  8. Acer Aspire 3 A315-21-92FX Battery Replacement: Schritt 8, Bild 1 von 1
    • Use the iFixit opening tool to remove the cover of the hard disk.
  9. Acer Aspire 3 A315-21-92FX Battery Replacement: Schritt 9, Bild 1 von 2 Acer Aspire 3 A315-21-92FX Battery Replacement: Schritt 9, Bild 2 von 2
    • Pull the hard disk out of the Acer Aspire 3 A315-21-92FX slightly and slowly.
    • This laptop is missing the hard drive.
  10. Acer Aspire 3 A315-21-92FX Battery Replacement, Battery: Schritt 10, Bild 1 von 1
    • Remove fourteen 2.5mm Phillips #0 screws from the back of the laptop.
    • There may be two additional screws under the hard drive cover that must be removed before attempting to remove the back cover.
  11. Acer Aspire 3 A315-21-92FX Battery Replacement: Schritt 11, Bild 1 von 3 Acer Aspire 3 A315-21-92FX Battery Replacement: Schritt 11, Bild 2 von 3 Acer Aspire 3 A315-21-92FX Battery Replacement: Schritt 11, Bild 3 von 3
    • Use the iFixit opening tool to remove the back cover.
  12. Acer Aspire 3 A315-21-92FX Battery Replacement: Schritt 12, Bild 1 von 2 Acer Aspire 3 A315-21-92FX Battery Replacement: Schritt 12, Bild 2 von 2
    • Pull out the plug connecting the battery to the motherboard.
  13. Acer Aspire 3 A315-21-92FX Battery Replacement: Schritt 13, Bild 1 von 2 Acer Aspire 3 A315-21-92FX Battery Replacement: Schritt 13, Bild 2 von 2
    • Pull the battery out of the groove.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
ShengKun Lu
705 Reputation
3 Anleitungen geschrieben
York University, Team S1-G5, Woodhouse Winter 2020 Mitglied von York University, Team S1-G5, Woodhouse Winter 2020
YORK-WOODHOUSE-W20S1G5
3 Mitglieder
4 Anleitungen geschrieben
Ein Kommentar
Thanks for this tutorial ! You just forgot 3 screws: 2 on the right of the hard drive, and 1 on the top left =)
Troublicious - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 50
Letzte 30 Tage: 264
Insgesamt: 11,716
