Einleitung
This replacement guide will show you how to replace a full or faulty hard disk drive in your Acer Aspire 3 A315-21-92FX.
Physical or logical failure of your hard disk will cause operating system crashes in your Acer Aspire 3 A315-21-92FX. Before using this guide to replace the hard disk, make sure to check the troubleshooting page for ensuring that the problem is relative with the hard disk.
Was du brauchst
Flip the Acer Aspire 3 A315-21-92FX over, so the back-side is oriented to the upward position.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
My acer aspire 3 A315-32 says no bootable device I had tried to boot Linux from USB but I partioned the hard drive so I fixed it by changing the format and deleting everything and installed windows on a different pc but it’s still not booting even on boot options it’s not showing
These connecting cable is missing, where to buy these cable. Pls tell the cable name
