Einleitung
This quick guide is to show Acer Aspire 3 owners how to replace their laptop speakers. Laptop speakers can blow out from overuse, fail over time from extended use, or fail from accidents like water damage.
Was du brauchst
Close the laptop and flip it over.
Remove the eleven 6.5 mm Phillips screws from the lower case.
Insert an opening pick between the lower case and chassis.
Pry around the entire perimeter until the lower case releases.
Remove the lower case.
