Einleitung
The battery is the power source of the laptop, allowing it to be a device you can carry anywhere. If you feel like your battery is not holding a charge like it used to or is dying when it shows it has more battery life, then it is time for a new battery. This is an easy fix that only requires unscrewing a few screws. Make sure that the device is off for at least 1 minute and unplugged from anything.
Was du brauchst
Insert an opening tool into the seam between the lower case and chassis.
Pry along the perimeter until the lower case releases.
Lift off the lower case.
Use tweezers to grip the white battery connector and pull it directly out of its motherboard port.
