Einleitung
To reach any inside components of the laptop you must take the back case off of the laptop. It is an easy process that requires just unscrewing any screws and peeling off the case. This step is a prerequisite to anything relating to the inner components of the laptop. Ensure the device is unplugged and powered off for at least 30 seconds before opening.
Was du brauchst
Insert an opening tool into the seam between the lower case and chassis.
Pry along the perimeter until the lower case releases.
Lift off the lower case.
Eine weitere Person hat diese Anleitung absolviert.
