Einleitung
When experiencing issues with an SSD, whether it's due to crashing or reaching a reduced storage space limit caused by reaching a TBW (Terabytes Written) limit, it may be a good idea to replace the SSD (Solid State Drive). It is a straightforward fix, but to prepare for it, you must ensure the computer is unplugged from any chargers and powered off because you will need to have the device open.
Was du brauchst
Insert an opening tool into the seam between the lower case and chassis.
Pry along the perimeter until the lower case releases.
Lift off the lower case.
Eine weitere Person hat diese Anleitung absolviert.
